12 years agoQSYS output (synthesis) directory workaround?
Hello All, We recently started upgrading from SOPC builder to QSYS. There is one(...) big annoying difference between the two systems: When generating a system QSYS copies ALL files into a synt...
12 years ago --- Quote Start --- Because SOPC builder added the files directly to the project --- Quote End --- Hang on, read your original request above - you wanted to avoid copying the source to the Qsys directory :) Qsys will copy source if you use filesets that point to your HDL source. My workaround was to point the fileset to a .qip file (which gets copied), rather than the HDL. That way I can keep editing the HDL and rebuilding the system, without having to re-run Qsys (to get it to copy the modified source to its synthesis area). --- Quote Start --- there was no need to use any environment variables. This allowed to have multiple versions of the same source on my system - or have multiple projects with each their own copy of the source. --- Quote End --- If you don't like my use of environment variables, there are two other solutions; 1. The ::quartus() array is available in most of these tools. If the environment is inherited when one tool starts the next, then you can put a variable in ::quartus and access it in the downstream tools. 2. You can create a fake generic/parameter using set_parameter, and then access it later using get_parameter Personally I see no harm in setting a few environment variables :) Cheers, Dave
