9 years agoQsys not generating same files in Simulation folder for VHDL vs Verilog?
So I have wondered what is going on here and it seems there is a bug in the program. I am using Altera Quartus II 15.0 64 bit. I select SRAM/SSRAM controller from the IP catalog. Then I click gene...
9 years agoThis works fine here. If I create an empty Qsys with the SDRAM controller, select language "VHDL" and Generate the system, I am left with foo/simulation/submodules and foo/synthesis/submodules/ directories, both of which have identical copies of the Verilog instance of the controller.
I also have foo/simulation/foo.vhd with the top level. Are you confusing the "foo/simulation" subdirectory with the top-level "simulation" directory? Qsys puts everything in a new subdirectory of the same name as your Qsys file. The "simulation" folder in your Quartus project directory is for e.g. the gate level / timing accurate simulation models generated as an output of the Quartus compilation.
