9 years ago[Qsys] LPDDR2 Controller (UniPHY): HDL generation fails.
From the TerasIC Cyclone V GX Starter Kit (C5G) system cd v.1.2.2. (http://www.terasic.com/downloads/cd-rom/c5g/c5g_v.1.2.2_systemcd.zip), I use Qsys (16.1 under Windows 10 64-bits) to re-generate th...
9 years agoJust to rule out licensing, which I don't really think it is, you can install Quartus Prime Standard Edition and run it for 30 days, including the IP base suite. You could also install the older version that the design was created and originally compiled with so you don't have to recompile it.
That is really weird that a system with just the controller in it gave you the same error. I'm not sure what else to try.
