9 years ago[Qsys] LPDDR2 Controller (UniPHY): HDL generation fails.
From the TerasIC Cyclone V GX Starter Kit (C5G) system cd v.1.2.2. (http://www.terasic.com/downloads/cd-rom/c5g/c5g_v.1.2.2_systemcd.zip), I use Qsys (16.1 under Windows 10 64-bits) to re-generate th...
9 years agoSo you're getting this error when you try to generate the system in Qsys? It looks like you're using the Lite version of Quartus Prime which does not include a license to the IP Base Suite which includes the memory controller IP (https://www.altera.com/products/intellectual-property/design/ip-base-suite.html). Not sure if that's the issue.
Try this: in Qsys, double-click the controller to open its parameter editor. Edit a setting and then put it back to its original value. Then try generating the system again.
