ThomasTessier
2 years agoqsys-generate for *.ip files says deviceFamily "Agilex 5" is out of range?
I am migrating my command line simulation build environment from Quartus 21 to Quartus Prime Pro 24 and noticed that the way I was generating my simulation files is no longer supported. It seems that...
- 2 years ago
The solution was to force and update of the IP blocks and that seemed to resolve the problem. I was unclear of what exactly changed in the *.ip files to make it work but it was happy after I did this.
TomT...
ShengN_altera
2 years agoHi TomT,
If generate other IP from GUI with device Agilex 5, does it causes any problem?
For command qsys-generate, use these options --family=<value> and --part=<value> check this link https://www.intel.com/content/www/us/en/docs/programmable/683364/18-1/qsys-generate-command-line-options.html does it helps?
Sheng
