11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years ago@dave: I continued your suggestion, by putting hard paths in my .qip-file. E.g.
set_global_assignment -name VHDL_FILE -hdl_version VHDL_2008 -library UdpToFrame /SCM/FPGA/BuildingBlocksV2/IP/UdpToFrame/Source/Common_pkg.vhd this seems to work, but GREATLY reduces flexibility of where we can check-out the files. A relative-path solution would be preferred.... In the code in your link you seem to refer to an environment variable ($::env(VHDL)). Would work, but isn't there a nicer way? @anybody else then dave: your help is also appreciated ;) Should I kick-off a change-request at Altera?
