11 years agoQSYS flattens our design hierarchy
Hi all, We are migrating from Xilinx to Altera and so far everything is running ok. As an alternative to Xilinx IP-integrator, we've now moved to QSYS. Here we get problems. First issue: I...
11 years agoLets say I am generating a QSYS project "unsaved" with two IP blocks: TsToUdp and UdpToFrame.
The TsToUdp_hw.tcl has the line:add_fileset_file ./TsToUdp/Common_pkg.vhd VHDL PATH Common_pkg.vhd The UdpToFrame_hw.tcl has the line: add_fileset_file ./UdpToFrame/Common_pkg.vhd VHDL PATH Common_pkg.vhd these are different versions of the same package, so they have different contents! But QSYS generates the file unsaved.qip with the following lines: set_global_assignment -library "unsaved" -name VHDL_FILE
set_global_assignment -library "unsaved" -name VHDL_FILE Thus both files are compiled into the same library, one overwriting the other! This will cause one of our IPs to fail during synthesis. I would like QSYS to generate the following: set_global_assignment -library "UdpToFrame" -name VHDL_FILE
set_global_assignment -library "TsToUdp" -name VHDL_FILE
