11 years agoQSYS feature-request: timing interface type
Hi all, given the version 15's interface-types, it is unnecessarily difficult to distribute control signals in a (nested) QSYS component and thus implement serial data processing. Streaming dat...
11 years ago --- Quote Start --- Hi josyb, Apologies, I was not aware that the forum will scale them down. --- Quote End --- --- Quote Start --- That's not true. clock and reset do not come with the data. They are distributed in an independent topology. --- Quote End --- I maybe should have said: "Everything comes along with the data, except clock and reset which are distributed globally" --- Quote Start --- I would be fine to use the clock- and reset-interface types if only I could extend them to include my own control-signals. --- Quote End --- --- Quote Start --- What would you suggest for components like "Costas" that do receive two input streams? The realization *can* be very tiny because these inputs streams are in sync. --- Quote End --- I have a simple Qsys component to combine two streams into one, and I have written several components that accept two (or more) input streams. No sweat. --- Quote Start --- I could of course let the optimizer infer that the control-signals for both inputs are in fact the same. But if I do so, I must at least do a realization that also works with two different control inputs (if I want to keep the component reusable). And I'm not sure that the optimizer will do the same radical simplification that I can do with the knowledge that the control-inputs will always be identical. I do not feel comfortable with that solution. I must admit that I did not look into alternatives deeply. But the QSYS tcl-scripting seemed a very powerful instrument. --- Quote End --- You mention Verilog, but if you'd step up to SystemVerilog, or VHDL - what I use(d)- you could use a struct (SV) or record (VHDL) to encapsulate your control signals making adding/deleting of a control signal quite easy, because every component picks what it is interested in. --- Quote Start --- The controller is an interesting unit. It is in Verilog, but the signals are not formulated as HDL-logic. Instead they are read of an initialized ROM. And the ROM is initialized from a MIF that is generated by the _hw.tcl, dependent on parameters. There are two reasons for this:
- I need very strange address-sequences for some RAMs (in the controlled components), that are hard to formulate as logic, but easy to precompute in TCL.
- The generated signals also include some bitserials constants. These are results of trigonometric functions, the input parameters depend on component-parameters. Again, very easy to precompute in TCL.
