15 years ago --- Quote Start --- ... hack the output HDL file to make the exported ss_n signal wider. --- Quote End --- I should have noted that that was the first thing I did. The compile process regenerates that file each time. Or it did in my environment. I was equally surprised. It seems that 'generation' of the SOPC is run for every compile. Or from this wicked-green-novice it appears to be that way. Thanks for your reply. -dave
