14 years agoAccording to the Avalon 2.0 spec:
When present, a slave port ignores all Avalon-MM signals unless chipselect is asserted. chipselect must be used in combination with read or write. The chipselect signal is not necessary; Altera does not recommend using it. Also when you created the component you mapped your waitrequest to the type "waitrequest_n" and not "waitrequest" right?
