13 years agoThis tutorial here:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Uses the Verification Suite Avalon-MM BFM for simulation stimulus generation, and the JTAG-to-Avalon-MM bridge in hardware. You can use that to test your own custom logic in simulation and then hardware (where you can Signaltap II trace your design). Cheers, Dave
