10 years agoQsys and basic signals
Hello All. Have problem with simple project with qsys. I am use onchip ram, and want write to address 0x000_000 2 bytes. I am add in qsys altera master template, all connect and 0 errors,...
10 years agoBut you need to attach the signals from your process to the signals from the onchip ram - so:
onchip_mem : hd_mem_onchip_mem port map ( clk => clk, address => address, clken => clken, etc. In your internal scope you are watching the onchip_mem signals, but nothing is driving them - hence they default to 1. The onchip_mem signals you've got on your entity hd_mem, so they are coming in from outside the chip at the moment - do you have anything driving these? You say in your original post that you want to write 2 bytes - where is the data you want to write coming from? This ultimately needs to connect to the writedata bus to your onchip memory.
