14 years agoQsys 11.0sp1 DDR2 Uniphy generation problems under suse
I am using Quartus 11.0sp1 on Suse linux 11.4 (64bit), and try to generate a
simple system with a nios processor, onchip memory and a ddr2 Uniphy controller in Qsys. The system generation works fine on a windows system but under linux I get the following error message: # ####### Info: c0: "ddr2ifc" instantiated altera_mem_if_nextgen_ddr2_controller "c0" Error: p0: add_fileset_file: No such file /tmp/alt5239_8498344429525475091.dir/0028_p0_gen/qsys/nios_ddr2ifc_p0_sequencer_rom.hex while executing "add_fileset_file $file_name [::alt_mem_if::util::hwtcl_utils::get_file_type $file_name 0] PATH $generated_file" ("foreach" body line 4) invoked from within "foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR2" $tmpdir SIM_VERILOG] { set file_name [file tail $generat..." ("if" then script line 2) invoked from within "if {[string compare -nocase [get_parameter_value NIOS_SEQUENCER] "true"] == 0} { foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_seque..." (procedure "generate_verilog_sim" line 19) invoked from within "generate_verilog_sim nios_ddr2ifc_p0" Info: p0: "ddr2ifc" instantiated altera_mem_if_ddr2_phy "p0"# ####### Does anybody have any hints? Thanks
