14 years ago
Qsys - simple design not working
I am not able to get this simple system working on Qsys.
However it works when I re-enter it with SOPC.
I am using Q11.0 and my hardware is Cyclone II.
This is what I do:
Generate the Qsys/SOPC file.
In Nois application I build the .elf file.
Then I do an elf2hex conversion.
I replace the .hex memory initialisation file for the Qsys/SOPC.
I am able to verify uptill this stage and all is fine.
In Quartus I update MIF and assemble.
A comparison of the output files (.sof/.rbf) does not make sense to me.
When I configure the Cylcone II hardware, SOPC works, but Qsys dosent.
I tried various setting but still could not get it up.
Could it be a BUG or am I missing something.
Any help is greatly appreciated.
    Connect Instruction Master bus and use proper vector assignment in cpu options in QSYS.
    Guru,
    I tried adding a custom instruction module (bit swapper) and tied the dangling stub. Blead for another half a day but still no results.
    I had worked earlier on cyclone IV with Qsys with no problems. But on Cyclone II the NIOS is deadbeef.
    Unable to bleed any further I have resorted to SOPC. It is a pain to export conduits, but no other go...
    My inference is Qsys does not work on Cyclone II !!
    Ravi
    I see that You've edited the system and now it probably doesn't work, because Your reset polarity is inverted. You use reset_n signal as system reset.
    I faced the similar problem.i use Qsys to build a custom instruction to counter the clk number if i input '1',while input '0' to clear the counter ,but when i generate the system,error comes like this:Error: nios2_qsys_0: Port no_ci_readra in TCL description is not found in the design file
    can you do me a favor?
