10 years agoQSys - Pin Planner won't accept PIN_W27 for PCIe Reset Input -Cyclone V GX DevelBoard
I have a problem with the pin assignment using Altera’s Pin Planner. I tried to set up a simple PCI express application with QSys and Quartus II. After set up the application, I would like to do the pin assignment for the FPGA. I am forced to use the Altera Cyclone V GX Development Board, because the Altera Cyclone V GT Development Board, which I have bought, was damaged. The pin assignment, which is mentioned in the “Cyclone V GX FPGA Development Board – Reference Manual” is equal with the schematic from the Installation Kit (Quartus II 12.0.2.1 – downloaded yesterday). PCIE_PERSTNW27LVTTL PCIE_REFCLK_PW8HCSL PCIE_REFCLK_NW7HCSL PCIE_RX_P0AG21,5 V PCML PCIE_RX_N0AG11,5 V PCML PCIE_TX_P0AF41,5 V PCML PCIE_TX_N0AF31,5 V PCML After starting the synthesis, I get the following message: “Error (16023): hard IP reset pin "PCI_RST" is assigned to illegal pin "PIN_W27". Change the pin assignment to pin "PIN_W24".” It could be important to know, that Altera marked the Cyclone V GX Development Board as “deprecated”. Does anybody know why? I have got the same problem with Altera’s PCI express example (“C:/altera/15.0/ip/altera/altera_pcie/altera_pcie_cv_hip_avmm/example_designs/ep_g1x1). It is possible to compile my PCI express application with the Pin Assignment of the Cyclone V GT board very well. I won’t change the PIN_W27 to PIN_W24 without knowing why. Furthermore, it is not possible to find the PCI express card within my Linux PCI tree with using PIN_W24. (I used the Cyclone IV GX Development Board before with the same host computer and it worked very well.) Is there a mistake in altera’s documentation? (It is not listed inside the errata sheet) Thanks for helping Greeting Thomas2 Replies
Have you got the exact FPGA selected? W27 should be a valid pin, it's nothing special.
The other option, is there anything else on the same bank? It may be you need to select an IO standard to match other things on the bank. - Altera_Forum
Wait, scratch that, that is exactly it. W27 is nothing special, which is exactly the issue.
W24 is the nPERSTL1 pin on the FPGA. The PERSTN pin must be on one of the nPERSTLx pins, so you cannot use W27. I presume there is an error in the board reference guide. You could always download the kit files and have a look at the schematic to see if the PERSTN signal is indeed connected to W24.
