10 years agoQSys - Pin Planner won't accept PIN_W27 for PCIe Reset Input -Cyclone V GX DevelBoard
Hi, I have a problem with the pin assignment using Altera’s Pin Planner. I tried to set up a simple PCI express application with QSys and Quartus II. After set up the application, I would ...
10 years agoHave you got the exact FPGA selected? W27 should be a valid pin, it's nothing special.
The other option, is there anything else on the same bank? It may be you need to select an IO standard to match other things on the bank.
