12 years ago
qsys - make connections based on parameters
Hi
I wanted to connect or disconnect 2 endpoints in qsys based on a Instance Parameter but I'm not sure this is possible.
Under the Instance Parameters tab I added a parameter "MAKE_CONNECTION" and gave it a default value of 1.
In the Instance Script I have the following code
proc compose {} {
    set make_conn
    if {$make_conn == "1"} {
        add_connection block1.out block2.in
However when I try to generate this I get an error -
invalid command name "add_connection
