Robert_PIN_ASAP
4 months agoQPP 26.1.0 Tools->Generate Simulator Setup Script produces no output
Hello, I have a relatively simple Agilex 3 QPP 26.1.0 project with four IPs on Win 11. Today after adding the latest IP block, running Tools->Generate Simulator Setup Script produces no output when...
ZiYingE_Altera
Contributor
4 months agoHi Bob,
Good day.
Just wanted to follow up on the other issue you mentioned. Were you able to generate the PLL IP after launching Quartus Prime Pro with Administrator privileges on that machine?
ZiYingE_Altera
Robert_PIN_ASAP
3 months agoHello,
FYI - I did create a new forum post regarding not being able to generate a PLL IP in QPP 26.1:
QPP 26.1 fails to generate PLL IP | Altera Community - 355132
