14 years agoThat's a good one..
One of two things.. It's a bug in the web addition. Or you are getting a licenses to someone else's subscription addition vi a LM_LICENSE_FILE variable on your system.. I would check the following: Goto help, about in Quartus II and report what it says. Mine says: Quartus II Version 11.0 Build 208 07/03/2011 SJ Full Version Service Pack Installed: 1 Mine is the Full version, so I would expect yours to say Web Edition. Then goto tools->License Setup and llook at what that says. There's also a Web License Update button in there. I know you can run the Full Version with a Web-License, and vice versa. It may be your web-license is about to expired, and you just need to grab a new one. Although I thought the last web-license I had didn't have an expiration date. If your license file line is in the form of <port>@<computername> and the computer name doesn't match your machine, you are probably picking up someone else license in your organization. Pete
