See the last section of the release notes for 9.1:
http://www.altera.com/literature/rn/rn_qts_dev_support.pdf Apex is not supported in this release. Jake - Altera_Forum
Hi, thank for your reply :)
I did go through the doc you sent me before, but the weird thing is that the software which installed in my uni's pc actually has the APEX20K in the device selection. (The version is 9.1 web edition) :rolleyes: - Altera_Forum
By the way, the uni's pc also did install the v9.0 web edition, in which I think it support APEX20K. Will they share the same library directory?
:confused:
