13 years ago
QII 13.0 Text Editor strange behaviour on text entry
I have a strange problem with text entry in QII's text editor, which makes typing really annoying.
Assume the line to be changed is at mid screen, some lines "above" and some below. Sometimes on typing (IIRC most time with autocompletion comeing up with suggestions or typing e.g. '(' of vector range defintion etc.) the editor scrolls the line where I'm typing to the upper or lower end of the entry window...
e.g.: Lines shown in text editor: 1935 to 2013. I "click in line 1968" to type text (being somewhat mid of screen). While starting to type the name of e.g. a signal, it's likewise I would have pressed PgDwn/PgUp as the active line is now either the first (editor shows now lines 1968 to 2046) or it's scrolled to be one of the last ones shown (editor shows 1893 to 1971). Closing this editor window and reopening sometimes fixes the problem, sometimes for some entries only, sometimes it's the same from the start...
That drives me crazy :-(
Are my files too large for the text Editor?
Is there something configuration Option set, that initializes this?
Best regards, Carlhermann
System: Win8, 64Bit / Quartus II 13.0 WebEdition...
1 Reply
    I would raise the issue with my support and then move to a better text editor (quartus text editor is functional, but nowhere near as useful as other text editors that are free).
    You can even set quartus to open your text files in an external editor: tools -> options -> external text editor.
