QII 13.0 License file
Hello
Welcome to INTEL forum. You could use Quartus WEB edition. For Quartus Web/lite Edition can request Quartus® II Software SW-QUARTUS-WE-FIX license in SSLC.
Here’s the steps:
1. Login to https://licensing.intel.com/
2. Go to Sign up for Evaluation or Free licenses
3. Select Intel® Quartus® II Software SW-QUARTUS-WE-FIX
4. # of Seats is always 1 for Quartus Web Edition
5. Check the T&C box
6. Click Get License button
a. Check the option product “Intel FPGA Software SII-NONVOLENCRYP”
b. Add New Computer or Assign an Existing computer
7. Add the required fields
8. Click Generate License
You will be taken to the Licensing page, and you should be able to receive the email with license attached
I have installed and use the web/lite versions of Quartus 13.0sp1, 16.0, and 21.1
Never have I needed to install a license file/code.
The web/lite (ie, free) version vs the standard/prime (ie, paid) version does not require a license be installed to run.
From the install guide for 16.0, for example:
Note: The Quartus Prime Lite Edition and ModelSim-Altera Starter Edition Software do NOT require a license. If you are using this software, you can skip the licensing step and begin using the software.
The other versions I use have similar language. So use the web/lite version if it supports the devices you have. Much easier.
