16 years ago
Q9.1: ECO and Smart Recompile
Hello
I experience two problems here right now that might be connected to the Quartus version:
- If I run quartus_sh -determine_smart_action, I always get SMART_ACTION = SOURCE, even if I just ran the mapper. Does anyone else have this problem?
- I just tried to commit an ECO change, but the fitter complains, that I first need to run the mapper with incremental compilation switched on for the top level. This is the case anyway and obviously there is a netlist available for the fitter (I used the tech-map viewer with post-fit data to do the change).
Does somebody know those problems and/or has a fix for it?
/emanuel
    i just ran the command on a full compile:
    Info: Command: quartus_sh --determine_smart_action s4gx_pcie
    Info: Quartus(args): s4gx_pcie
    Info: SMART_ACTION = DONE
    is it only after the mapper that --determine_smart_action fails? can you try after a full compile to see if we are getting the same results?
    Hi
    thanks for the test. I just tried after a full run. The result is still SOURCE.
    But then, doing the same on another workspace of the same project, it seems to work (i.e. FIT after the mapper, DONE after a full run).
    So i guess my database is somehow corrupted. I will clean that up and check again.
    Thanks for the input and sorry for the early alert
    Emanuel
