11 years ago
PWM signal via sine-triangle comparison
right now i am stuck in aproblem in my project. I hope its not explained to complicated and someone can help me (-:
I try to generate a pwm signal out of a sine with 50 Hz - 20ms.
I have triangle function with a period time of 8 µs by counting from -99 to 99 and vice versa.
I have a sine table with 500 values, so if i want to fit the whole sine into the 20ms period
and i have the triangle with a period of 8µs (400* 20ns) i have to update the sine value every 40µs.
Now i simulated everything and it compiles just fine but i think my design is full of logical errors which i right now cant see.
In the modelsim analysis i see a close pwm signal but with the wrong amplitude, so that the sine function is much larger than the triangle.
I hope someone can help me and thanks in advance for reading through my code!!
Cheers
Tim
-------------------------Timer Direction Function--------------------------------
TimerDirection:process (CLOCK,RESET,TimerDir,Timer)
begin
    if  RESET = '0' then
        TimerDir <= '1';
    elsif CLOCK'event and CLOCK ='1' then
        if (Timer =99) then
            TimerDir <= '0';
        end if;
        if    (Timer =-99) then
            TimerDir <= '1';
        end if;
    end if;
end process TimerDirection;
CountingTimer: process (CLOCK,RESET,TimerDir,Timer)
begin
    if  RESET = '0' then
        --Timer<= (others => '0');
        Timer <= 0;
        countSine <= 0;
        if (TimerDir ='1') then
            Timer <=Timer + 1;
        end if;
        if (TimerDir ='0') then
            Timer <=Timer - 1;
        end if;
        countSine <= countSine +1;
        if    (countSine = 2000) then
            countSine <= 0;
        end if;
    end if;
end process CountingTimer;
type table is array (0 to 499) of std_logic_vector(8 downto 0);
function init_table return table is
    variable var: table;
    variable x: real;
    begin
        for i in 0 to 499 loop
            x:= SIN(real(i)*MATH_PI/real(500));
            var(i):=std_logic_vector(to_signed(INTEGER(x*real(100)),9));
        end loop;
    return var;
end;
constant sinTable : mem := init_mem;
this function generates the pwm signal:
modulate: process (CLOCK,RESET,TimerDir,Timer)
begin
    if RESET = '0' then
        PWM_OUTPUT <= '1';
        if SinValue = std_logic_vector(to_signed(Timer,9))  and  (Timerdir<='1')then
            PWM_OUTPUT <= '0';
        end if;
        if SinValue = std_logic_vector(to_signed(Timer,9))  and  (Timerdir<='0')then
            PWM_OUTPUT <= '1';
        end if;
    end if;
end process modulate;
end pwm_process;
    I have come across a variety of ways to do pwm based on counters, sine lut, triangle ...etc.
    I have the following algorithm to add to the list:
    no need for sine table, just a triangular table say from 0~256~1 (512 points) implemented as rom lut
    run an accumulator to generate pointer to lut, the accumulator starts from 0 adds tuning word modulo 512 (same as nco idea)
    tuning word for accumulator in my example = 512*f/clk
    then select in logic your threshold,
    threshold = duty * 256/100 i.e. scale duty to 256
    if lut output stream is checked in logic above threshold so output high else low
    thus you control frequency and duty cycle.
    you can also add initial phase control by adding a constant at start of accumulator.
    The sinvalue generation is missing from the code snippets, so we can't see where it probably goes wrong. Without the code, I don't understand at first sight how 2000 (actually 2001) sine samples are using a 500 point half-sine table and how the negative halve is generated.
    A possible trapdoor is the PWM compare for equality which can cause dropouts when sinvalue changes immediately at the crosspoint. Generally you'll decide for natural versus regular sampling and then implement a method that doesn't lose PWM edges.
    Hi, thanks you two for your replies and your time !!
    Hey FvM, the idea was to use natural sampling, how could i loose those pwm edges?
    i checked my sine vector in modelsim and it really seems that i just have half a sine, buthow does this happen.
    I thought when the variable x gets calculated its range is from 1 to -1 and this value is casted and stored in the vector?
    I have the period of 20 ms in which i put 500 sine values. The triangular impulse has a period of 8µs.
    So after 5 triangle impulses i need a new sine value.
    So i have the countSine value run to 2000 and update the sinetabe
    The compare function gets a new sine value every 5
    Right now i dont know why i just didnt divide the sine in 5000 intervals seems much more
    intuitive...
    I post the complete code with some comments below:
    Cheers
    Tim
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    --use IEEE.STD_LOGIC_ARITH.ALL; --bad
    --use IEEE.STD_LOGIC_UNSIGNED.ALL;
    use IEEE.STD_LOGIC_SIGNED.ALL;
    use IEEE.NUMERIC_STD.all; --good  --to_unsigned to_signed  <- integer to ..
    use ieee.math_real.all;
    entity PWM is
        Port (
    		CLOCK             : in  STD_LOGIC;
    		RESET             : in  STD_LOGIC;
    		PWM_OUTPUT        : out STD_LOGIC
    end PWM;
    architecture pwm_process of PWM is
    SIGNAL Timer          	: integer range -2048 to 2047 := 0;
    SIGNAL countSine    		: integer range 0 to 4095 := 4095;
    SIGNAL incSineTable		: integer range 0 to 500 := 500;
    SIGNAL TimerDir        	: STD_LOGIC :='1';
    SIGNAL SinValue			: std_logic_vector(8 downto 0) := (others =>'0');
    	variable x: real;
    	begin
    			x:= SIN(real(i)*MATH_PI/real(499));
    		end loop;
    	return var;
    end;
    constant sinTable : table := init_table;
    begin
    --input clokc 50 MHz Timer counts to 200 -> 8µs period time
    begin
    	if  RESET = '0' then
    		TimerDir <= '1';
    		if (Timer =99) then
    			TimerDir <= '0';
    		end if;
    		if	(Timer =-99) then               --1
    			TimerDir <= '1';
    		end if;
    	end if;
    	--end if;
    --------------------------------Timer  counting-----------------------------------
    begin
    	if  RESET = '0' then
    		Timer <= 0;
    			Timer <=Timer + 1;
    		end if;
    			Timer <=Timer - 1;
    		end if;
    	end if;
    -------------------------------Update Sine Value --------------------------------
    -- Timer 2500 cycles in 20ms 500 sine values
    -- every 5 cycles new sine value -> countSine to 2000
    UpdateSineValue : process (CLOCK, RESET)
    begin
    	if RESET = '0' then
    		incSineTable <= 0;
    		countSine <= 0;
    		SinValue <= sintable(incSineTable);
    		if incSineTable = 500 then
    			incSineTable <= 0;
    		end if;
    				incSineTable <= incSineTable +1;
    			end if;
    	end if;
    end process UpdateSineValue;
    ---------------------------- TimerCompare Function----------------------------
    TimerCompare: process (CLOCK,RESET,TimerDir,Timer)
    begin
    	if RESET = '0' then
    		PWM_OUTPUT <= '1';
    		--if (SinValue = to_signed(Timer,8))  and  (Timerdir<='1')then
    			PWM_OUTPUT <= '0';
    		end if;
    			PWM_OUTPUT <= '1';
    		end if;
    	end if;
    end process TimerCompare;
    end pwm_process;
    The following code implements pwm based on 15 bits phase accumulator.
    You need to provide:
    frequency word as : round(2^14*freq/clk)
    duty cycle as: round(duty*2^14/100);
    it does not require actual LUT but is implied
    library ieee;
        use ieee.std_logic_1164.all;
        use IEEE.numeric_std.all;
        entity pwm is
        port(
            clk           : in  std_logic;
            freq_word     : in  std_logic_vector(13 downto 0) := "00011001100110";
            duty_scaled   : in  std_logic_vector(13 downto 0) := "10000000000000";
            pwm           : out std_logic
        end entity;
        architecture rtl of pwm is
          signal ptr : unsigned(14 downto 0) := (others => '0');
          begin
          process(clk)
          begin
            if(rising_edge(clk)) then
               ptr <= ptr + unsigned(freq_word);
               pwm <= '0';
               if ptr(13 downto 0) < unsigned(duty_scaled) then
                   pwm <= '1';
               end if;
            end if;
          end process;
        end rtl;
    and here is a model in matlab
    clear all; close all; clc;
    clk = 100;  %system clock
    f = 10;     %output frequency
    duty = 50;  %output duty cycle, 1 ~ 100
    %%%%%%%%%%%%%%%%% LUT %%%%%%%%%%%%%%%%%%%
    n = floor(5000/f);         %test length
    m = 15;                    %lut resolution
    tw = round(2^(m-1)*f/clk); %tuning word
    ptr = 0;                   %pointer to lut
    for i = 1:n
        ptr = floor(mod(ptr + tw, 2^(m-1)));
        y(i) = ptr; %compute lut output
    end
    %%%%%%%%%%%%%%% comparator %%%%%%%%%%%%%%%
    threshold = round(duty*2^(m-1)/100);
    out = zeros(1,n);
    for i = 1:n
      if y(i) < threshold, out(i) = 2^(m-1); end
    end
    %%%%%%%%%%%%%% check results %%%%%%%%%%%%%
    figure;plot(out,'.-');grid;
    d = diff(find(diff(out))); %locate 0/1 transitions
    for i = 1:2:length(d)-1
        a = clk/(d(i)+d(i+1));
        b = round(100*d(i+1)/(d(i)+d(i+1)));
    end
    achieved_freq = mean(a)
    achieved_duty = mean(b)
    hey kaz,
    I could implement a triangular LUT.
    But i dont understand whats the idea behind the pointer and the tuning word.
    --- Quote Start ---
    --- Quote End ---
    Could you please this a bit more in detail ?
    thanks a lot!!
    Tim
    --- Quote Start ---
    hey kaz,
    thanks a lot!!
    Tim
    --- Quote End ---
    The idea comes from NCO but instead of generating sine the same concept is applied to a triangular cycle.
    The nco is based on one cycle worth of sine data (half or quarter can be used but eventually read into 1 cycle).
    A pointer is used to address lut based on phase increment... you will need to research into say DDS tutorial from AD for full explanation.
    I applied same idea but instead used triangular cycle and then realised I don't even need the LUT but just visualise it conceptually to save memory and use high resolution. The triangular cycle is 0:2^14 then back to 1(2^15 points in effect)... look at matlab model and change variois parameters to see how it responds.
    Bear in mind that as you get close to clk speed the samples per cycle gets less and affects resolution of duty cycle
    Here you are generating a half sine wave. The range of a full wave would be 0 to 2*pi. I also think that the division factor should be 500.0 instead of 499.0.
    You want something like this
      x:= SIN(real(i)*2.0*MATH_PI/500.0);
    Secondly, your counters are counting one step too much, e.g. incSineTable counts 498, 499, 500, 0, 1 ...
    Wow,
    thats super cool!
    i simulated the code and i dont understand many things but i will study it Thank you
    I now realized why my pwm signal was so "strange"
    I did not scale the sine correct to the triangle counter.
    I switched back to count from 0 to 100.
    And the i multiplied each sine value with 50 and added an offset of 50 to it. Now i have the desired output signal.
    Thank you both for your help and time!!
    I did not follow the NCO idea because i did not fully understand the principals (-;
    Cheers
    Tim
    	variable x: real;
    	begin
    			var(i):=std_logic_vector(to_signed(INTEGER(50.0 + x*50.0),10));
    		end loop;
    	return var;
    end;
