12 years agoHi Francisco,
--- Quote Start --- I'm trying to understand and test this code, yet I keep receiving errors --- Quote End --- Start by running the existing testbenches. --- Quote Start --- do I have to create two separate VHDL files in QUARTUS to run this, one for the testbench and one for the LFSR? --- Quote End --- Quartus is for *synthesis* only. A testbench is for simulation only, and is run in Modelsim. If you have written C-code before; you component is equivalent to your C-code, while the testbench is equivalent to a unit test. --- Quote Start --- My goal is to generate a random set of bits in order to output a random voltage signal trough the GPIO pins in my DE2 board then I will connect it to a transmitter circuit. --- Quote End --- You will not get a random voltage. You will get a stream of 0s and 1s that occur in a random order. --- Quote Start --- This circuit depends on a MOSFET, Resistor, and the transducer. --- Quote End --- Make sure your GPIO can drive the MOSFET correctly, eg., a power MOSFET requires more current than a GPIO can supply. --- Quote Start --- Yet, my first step is understand how to build a LFSR to generate the signal --- Quote End --- Simply instantiate the LFSR component. Here's what you need to do.
1. Start Modelsim.
2. Change directory to where ever you unzipped the zip file
Modelsim> cd {c:\temp\lfsr_tutorial_src\prbs}
3. Source the simulation script
Modelsim> source scripts/sim.tcl
4. Run the testbench
Modelsim> lfsr_tb
Now read the code (VHDL and Tcl scripts), and try to understand it. Cheers, Dave
