12 years agoNow I got the code down to 4 errors yet I do not what to change.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity PRNG22 is generic ( width : integer := 8 ); port ( clk : in std_logic; random_num : out std_logic_vector (width-1 downto 0) --output vector ); end PRNG22; architecture Behavioral of PRNG22 is --Input and Output definitions. signal clk : std_logic := '0'; signal random_num : std_logic_vector(3 downto 0); -- Clock period definitions constant clk_period : time = '1' ; begin variable rand_temp : std_logic_vector(width-1 downto 0):=(width-1 => '1',others => '0'); variable temp : std_logic = '0'; -- Instantiate the Unit Under Test (UUT) uut: entity work.random generic map (width => 4) PORT MAP ( clk => clk, random_num => random_num ); PROCESS_1: process(clk) begin if(rising_edge(clk)) then temp := rand_temp(width-1) xor rand_temp(width-2); rand_temp(width-1 downto 1) := rand_temp(width-2 downto 0); rand_temp(0) := temp; end if; random_num <= rand_temp; end process PROCESS_1; ------------------------------------------------------ --The test bench for the code is given below: -- Clock process definitions clk_process :process begin clk <= '0'; wait for clk_period/2; clk <= '1'; wait for clk_period/2; end process; END Behavioral;
