12 years agoHere's a PRBS tutorial with source code:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip You can also use a linear chirp signal and pulse compression for distance measurement (even if it is only a 1-bit output). Cheers, Dave
