16 years ago --- Quote Start --- have a project that pass's data from high speed serial link to a usb device. when i compile under 9.0sp1 the system works fine. compile under 9.1 and all though it has the appearance of working, i.e. passing data, the 'data is corrupted'. anyone else had problems with 9.1? --- Quote End --- Hi, did you get other Warnings .... Maybe the defaults settings are different .. Kind regards GPK
