MHamz1
7 years agoProgramming Using Command Line
HI,
I am using the following command to program the CPLD from command line
start quartus_pgm -z --mode=JTAG --operation="p;C:\Test Firmware\CPLD_U1.pof@1"It runs the quartus_pgm and exits on success or failure. I am unable to view the output as it quits immediately.
Can anyone suggest me a way to look if the programming was successful or not and how to read the output of quartus_pgm
- JohnT_Altera
Are you running this is command prompt? What do you mean by quit immediately?
- MHamz1
Yes I was running through the command prompt and the command prompt was closing as soon as the programming finished.
I have found a solution to add the /B /WAIT before the command .
Thank you
