MHamz1
7 years agoProgramming Using Command Line
HI, I am using the following command to program the CPLD from command line start quartus_pgm -z --mode=JTAG --operation="p;C:\Test Firmware\CPLD_U1.pof@1" It runs the quartus_pgm and exits on su...
JohnT_Altera
7 years agoHi,
Are you running this is command prompt? What do you mean by quit immediately?
- MHamz17 years ago
Yes I was running through the command prompt and the command prompt was closing as soon as the programming finished.
I have found a solution to add the /B /WAIT before the command .
Thank you
