17 years ago --- Quote Start --- Also if anyone's interested, I have a solution for using a large parallel flash device to bootload an Altera (Stratix 3) using an EPM570. This uses the (not very well documented) EPM370's ability to direct part of its JTAG chain to the user programmable part of the array. --- Quote End --- In which regard is your solution different from Altera MAX II PFL design (AN386)?
