Niko3
3 years agoProgrammer: Kernel mode driver not installed
Hi, I'm new with Quartus and have the following problem: After starting the programmer, click on "Hardware Setup..", select USB-Blaster, and click on "Add Hardware" then in the window plopping up th...
Niko3
3 years agoOne of the two .sys files in your configuration is different from mine. I have edevmon.sys instead of USBPcap.sys and
the provider is ESET instead of FTDI ltd.
I will look for FTDI drivers.
Thank you.
_AK6DN_
3 years agoYou have never stated what operating system you are running on? WIndows or Linux? Exactly what version.
If you want reasonable help you need to state your system configuration exactly, as it matters for software install and issues.
