11 years ago --- Quote Start --- I just went through the schematic I posted and looked at the devices connected to VCCIO, and they all should operate fine at 2.5V and 3.3V. I do not see an issue in the board design that would cause JTAG not to work with VCCIO set to 2.5V. I'll test the board I have at work tomorrow and see if it fails ... Can you post a link to the "other forum" discussion? Cheers, Dave --- Quote End --- Hi Dave, The discussion on this forum discusses the BeScope design which uses the BeMicroCV. Post# 67 mentions the jumper to fix the programmer. http://forums.parallax.com/showthread.php/156989-bescopebundle-tip-for-those-who-want-to-buy-an-fpga-development-board/page4 I was having the same issue and changing Vccio=3.3V fixes the communication issue. I haven't researched enough to figure out why this is. Thanks Carl
