11 years ago --- Quote Start --- I found this solution on another forum and it fixed the issue. Please rotate jumper J11 clockwise from the default 1-3 position(Vccio=2.5V) to 1-2 (Vccio=3.3V). --- Quote End --- I just went through the schematic I posted and looked at the devices connected to VCCIO, and they all should operate fine at 2.5V and 3.3V. I do not see an issue in the board design that would cause JTAG not to work with VCCIO set to 2.5V. I'll test the board I have at work tomorrow and see if it fails ... Can you post a link to the "other forum" discussion? Cheers, Dave
