12 years agoprocessing element and work items
Hi there, I have a general question here. If I compile a kernel with BLOCK_SIZE=32, SIMD_WORK_ITEM=2, 2-D work groups. The kernels has attributes as: __attribute((reqd_work_group_size(BLOC...
12 years agoFPGA hardware is different than GPU where there is hierarchy of streaming processors, kernels, warps, etc.
The compiler generates one or more compute units controlled by num_compute_units; the width of the compute unit is controlled by the num_simd_work_items. Work-items specified in the host are executed on this compute unit in a pipelined fashion. Ideally, every cycle a new work-item will be issued to the compute unit. If there are no stalls, every cycle a work-item will exit the compute unit.
