Altera_ForumHonored Contributor12 years agoprocess inside another process? Can there be a process inside another process ? I want to put a process inside a for loop. so since the for loop cannot be written outside a process, i weanted to put the for loop also in one ...Show More
Altera_ForumHonored Contributor12 years ago --- Quote Start --- the purpose is to design a BER Tester. And when t=0 and j=0 it will be d(0) --- Quote End --- sry yes. the code had glitches.
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
