14 years ago
Problems with Setup New Hardware
I've just bought a BeMicro evaluation board from Arrow and I followed their tutorial (I tried putting the link for the tutorial in here but, since I'm a new user, I can't post links yet) till section 5.3. Everything was going very well, but when I had to enter Programmer and setup new hardware, Quartus can't fin my Arrow USB Blaster. I don't know why, I installed the drivers correctly. I tried reinstalling them, but Arrow-USB-Blaster still doesn't show up on that drop box.
I'm running Quartus on Windows 7 Starter 32-bits.
Does anyone knows what's going on?
Daniel K. Franch
    I am running the latest version available, 11.0. The instructions were using version 9.1, but I assumed that using a newer version wouldn't be a problem.
    --- Quote Start ---
    --- Quote End ---
    Well, that's the only difference we have in setups now ... if you can try installing version 10.1 ... :)
    Cheers,
    Dave
    Well, I really don't know what's going on. So I should probably try installing this version.
    update: I left the other computer downloading Quartus II 9.1, as seen on the BeMicro instructions. Since I already have 5 posts, I can send some links here:
    http://bit.ly/bemicro_instructions - the instructions that I'm following
    http://yfrog.com/gzarq0p - the device manager, showing that the drivers are correctly installed (it is in portuguese, since I'm from Brazil. But what's essential for this problem can be seen here without any linguistic issue)
    http://yfrog.com/h835htp - the problem I get in the programmer tool in Quartus II 11.0
    update 2: So, I installed Quartus II 9.1 in the Win XP Computer and I still get the same problem. I'm really running out of ideas of solutions. Is it something with the JTAG maybe?
    Well, I searched all the web. Here in Altera Forum I found another thread with someone experiencing the same problem. But they nobody could provide a solution also. I just sent an e-mail to Arrow asking about this, although they suggest using the forums as support.
    And last time I tried sending them an e-mail, they never answered me back.
    I just feel I wasted my money on this board.
    The photos you posted indicate the driver is installed Ok.
    So 9.1 did not work huh?
    On my Windows XP machine I have 9.0SP2, 9.1, and 10.1 installed.
    Both 9.1 and 10.1 can be used to program the board.
    I'm not really sure what could be the problem.
    Ask Arrow if you can get your money back, or exchange the board for the BeMicro-SDK; it has a true USB-Blaster built into it (though the Mobile SDRAM on the board can be a pain to use ... last time I tried anyway).
    If you want to try someone else, look at the boards from Terasic.
    Cheers,
    Dave
    I'm glad that at least the drivers are ok. The problem is probably with Quartus then?
    Neither with version 9.1 nor 11.0 I could get past through this step with the Programmer tool.
    It seems that nobody knows what is really going on.
    And it happened in two different computers. Maybe it is really something going on in the BeMicro board. Can it be a faulty board sent to me by Arrow?
    I hope that this time they answer me.
    But is also complicated if they send me another board because taxes here in Brazil are incredibly high. Almost 40% of what I spent with this board was just in taxes.
    --- Quote Start ---
    --- Quote End ---
    I'm really not sure. The biggest pain with the BeMicro board is that it does not use the standard Altera USB-Blaster circuit.
    --- Quote Start ---
    --- Quote End ---
    Anything is possible.
    I don't really have any other suggestions. I have been looking at direct access to boards using the FTDI D2XX drivers. Those drivers can be used to access the BeMicro. However, I have not done any work with the BeMicro yet. I won't get a chance to look at it for a while either, so cannot offer any code.
    If you wanted to debug the board, look at the FTDI JTAG example designs. I'm pretty sure that Arrow have just wired the BeMicro according to FTDI's recommended JTAG circuit on port A, and then have a serial connection for port B.
    This is a lot more work that you'd planned on, but you might learn something useful.
    Cheers.
    Dave
    --- Quote Start ---
    Cheers.
    Dave
    --- Quote End ---
    Well, Arrow has answered me and said that someone from support will send me an e-mail very soon. I hope so.
    Meanwhile, I will probably try looking these FTDI JTAG example designs. It does look like much more work than I have planned, but it also seems to be interesting. As you said, I will probably learn something.
    Thank you. :)
    Oops. Sorry I haven't showed up anymore.
    So... Arrow never answered me back. I got support from NUI Group forums. Apparently I have installed the plug-in descriped in step 1.5 of Arrow's guide in the wrong directory.
    It was my mistake, but still I wouldn't recommend buying Arrow's stuff. Their support was terrible and simply ignored me.
    Still, thanks for everybody that tried to help me. But this question is solved. Is there some way to put a tag [SOLVED] in the title of the thread, like in Ubuntu forums?
