14 years ago --- Quote Start --- Bring-up the Quartus programmer (Tools->Programmer). The 'Hardware Setup' button on the programmer should have Arrow-USB-Blaster next to it. If it does not, click the button. Under available hardware, you should see Arrow USB-Blaster. Double-click it to select it, and then click Close. You should now be able to scan the JTAG chain. Cheers, Dave --- Quote End --- That's the problem. When I go to Hardware Setup Arrow USB-Blaster doesn't show up in avaiable hardware. All I get is "No Hardware". And I just checked here in the Win XP's device manager and "Arrow USB-Blaster Port A" and "Arrow USB-Blaster Port B" show up correctly installed. And I don't have anything else plugged in USB or Serial Ports.
