14 years ago --- Quote Start --- In Quartus, you should be able to bring up the programmer tool, and set it up to use the Arrow-USB-Blaster. Once you have selected that hardware, you should be able to scan the JTAG chain and find the FPGA on the BeMicro. Once you have that working, you can program the device. I have seen the tool 'fail' to program when using the Arrow-USB-Blaster, but when you try again, it works ... who knows why ... Cheers, Dave --- Quote End --- But that is exactly the problem. When I run the programmer tool, in that part of "setup new hardware", it doesn't read the Arrow-USB-Blaster. I tried reinstalling the drivers, then I tried to download Quartus in a machine running on Win XP, installed and reinstalled the drivers in this machine and it always show "No hardware". I will try making the project all over again tonight, but I don't know if this will do. I'm really new to this world. This is the first fpga-based board I am using, so I am kind of confused with it. But thanks for the help :).
