13 years ago --- Quote Start --- Hi, I think you must intall the Stratix V devices during the Quartus 13 installation . For this, you have to place the device installer "stratixv-13.0.0.156.qdz" qdz file in the same directory with the Quartus 13 installer .So when you launch the Quartus installer "QuartusSetup-13.0.0.156.exe" the installer can recognize stratix V devices before the installation. You might have something like in attached file --- Quote End --- Yes, you are right and that was the first thing I did. When I saw Quartus did not recognize the installed devices I tried to install using the built in device installer. That did not work either... Were you able to install StratixV devices like this on Windows 7? When you launch Quartus do you get a pop up message saying Quartus was installed succesfully but no devices were installed? Thanks. PS: I've also tried to install using quartus_sh on the command line but quartus_sh expects .qda files and would not accept .qdz files.
