13 years agoYou can find Signal Tap in Quartus II under Tools menu. Then you add the clock for acquisition, the interesting signals, set how much samples you want to see and re-compile the design. The procedure is well described in Quartus II handbook and it is not complicated. You can see with Signal Tap what is really happening in your FIFOs and debug it easily.
