Altera_ForumHonored Contributor13 years agoProblems to write and read from an altsyncram Hello, I'm trying to implement the Sobel algorithm as a Nios2 custom instruction. I write one frame in one external DDR ram and after I change the color mode to gray scale. The trouble starts when I ...Show Morecode1.txt7 KBcode2.txt2 KB
Altera_ForumHonored Contributor13 years agoI can give you very generic advice: use ModelSim and do some simulations.
Recent DiscussionsConnection bit order between hierarchyFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)
