15 years ago --- Quote Start --- Hello - They are two different partitions; - No warnings regarding partitions or logic lock; - I've tried both, placement & routing and netlist only Anyway, I've implemented a workaround and created a new partition instead of exporting the older one. Some additional work on adjusting, but it worked fine. No idea on why the second imported partition does not appear as locked. Thanks and regards --- Quote End --- Hi, I saw this effect also, but only in case that both partitions tried to use the same resources. Do you have an overlap of the logiclock regions ? Kind regards GPK
