15 years ago --- Quote Start --- Hi all I'm having some trouble while trying to import a logic lock region into a new design. I got two design partitions, one of them gets imported without any issues, it appeas as "locked" and the correct fixed size, but the second one appears as "floating" and "undetermined" size. The procedure I've taken to export/import both of them was the same. Any tip on what I may be missing here? Thanks in advance. --- Quote End --- Hi, did you try to import two times the same partition into to your main project or a you talking about two different partitions ? Did have a look to your warnings ? Did you import placement and routing or the netlist only ? Kind regards GPK
