14 years agoJust thought I'd post a solution to the problem that I received from Altera as it might be of help to someone:
Need to run this first: jtagd and ignore the error it returns: getpid: Command not found. Then this works OK: jtagconfig --enableremote password The other thing I noted is that jtagd will exit after some minutes if no connections are made and you have to then repeat the above.
