13 years agoThank u Kosh271 for ur reply
to test the VGA controlleur i connected the data input to switches from the DE2 an i supplied it with 25MHZ it's as if i'm sending the same pixel information , the display changes when i change the code on the switches the clock rate of the VGA is 25MHZ the ROM block is at 50Mz the Dual RAM , write clock 50MHz , the read clock 25MHZ thank u so much
