Problem with Signal Tap Logic Analyzer
Hi @MSenk1
I haven't seen this internal error(IE) before. Could you help to share your design .qar file that could duplicate this error? As without duplication of the error from our side, it would be hard to find a workaround/solution.
* If your design is confidential, please help to create a simplified design that can duplicate the IE.
Please help to provide any specific steps on when this IE occurs, does it crash when you try to open the Signal Tap tool or running the tool ?
Please expect that any work involving engineering will take some-time (a few days to a few weeks) depending on the complexity of the issue.
If your project is urgent, I would recommend to use Quartus 21.1 as a temporary workaround.
Richard Tan
Hi Richard,
we were able to solve this issue internally.
Michael
- RichardT_altera5 years ago
Hi @MSenk1
Glad to know that you are able to proceed without any trouble.
Do you mind to share what you have done and how to resolve the error?
This may be helpful to those who come across similar issue.
Richard Tan
