Hello, Richard-san.
I additionally reran the following:
But the result was the same.
Only Quartus Prime standard 24.1.0.1077 and Quartus Pro 25.1.0.129 are installed on my PC.
Is the difference that I installed CDT 8.8.1 additionally?
https://www.intel.com/content/www/us/en/support/programmable/articles/000086893.html
I don't think it's a problem with the windows environment variables.
I have not yet run it in an environment where CDT 8.8.1 for Windows has been removed. I will try it tomorrow.
Regards, Hidetaka.
Hello, Richard-san.
I uninstalled Quartus Prime standard 24.1 and then reinstalled it.
I did not install CDT8.8.1 and generated the LPDDR2 IP again.
The result was the same; an error occurred when checking "Generate Example Design". If I uncheck it, generate completed successfully.
For the time being I will continue development without checking "Generate Example Design", but I would like this to be improved.
////////// error message
Error: Execution of script C:/Users/xxxx/AppData/Local/Temp/alt0224_5461300254259846718.dir/0008_LPDDR2_top2_gen/simulation/generate_sim_example_design.tcl failed
Regards, Hidetaka.
- Hidetaka10 months ago
Hello Richard-san,
I had another issue in the Support Community. I added "TBB_MALLOC_DISABLE_REPLACEMENT=1" to the system environment variables that Adzim-san told me about, and was able to generate the Example Design without any errors.See here.
I am unable to generate the Cyclone VGX LPDDR2 controller IP due to an error. - Intel Community
I am very grateful to you.
Please close this issue.
