13 years agoIf possible, it is easier to start with one of the example projects from the kit and add your custom component to it. Then you don't have to redo the whole mapping, just modify the QSys instance in the top level file by adding your PWM output, and connect it to one of the LEDs (in the example project the LEDs are most probably connected to a PIO).
