14 years ago
problem with initialising rom and reading data
I would like to read binary data from a text file. Perform FIR filtering on the data and store the simulated result values in another text/mif file for further processing in Matlab. I used $readmemb function with verilog code in Quartus II. The following code seems to work.
module test(addr_a,addr_b,clk,q_a,q_b,c);
input [3:0] addr_a,addr_b;
input clk;
output [3:0] q_a,q_b;
output [7:0] c;
reg [7:0] c;
reg [3:0] q_a,q_b;
parameter data_width=4;
parameter addr_width=4;
reg[data_width-1:0] rom[2*addr_width-1:0];
initial
begin
$readmemb("script.txt",rom);
end
always@(posedge clk)
begin
q_a<=rom[addr_a];
q_b<=rom[addr_b];
c<=q_a+q_b;
end
endmodule
But instead if I use the following, my code does not work.
begin
x[0]<=rom[n];
n<=n+1;
temp<=x[0];
end
I don't want to use the address as input signal. I would like to use a counter to fetch the subsequent addresses. Could someone suggest me how to do that.
    It's not clear to me what you intend with the code that does not work.
    However, the code that does work will have to be the basis of what you want.
    Instead of having the address as a input to your module, you can simply generate the address(es) inside it. Something like:
    reg addr_a = 4'h0;
    allways @ (posedge clk)
    addr_a <= addr_a + 4'd1;
    reg addr_a = 4'h2;
    addr_b <= addr_b + 4'd1;
    Thank you. Yes, I wanted to know how to access address values without assigning addr as input.
    I appreciate your help.
    Ambrin
